Nucknoilerfan
- Nov 6, 2003
- 64
I have an older, late 70's or early 80's, 9.8 Merc that seems to miss when it runs. I've replaced the plugs and the leads off the coils as well as rebuilt the carb. I thought that it might be an ignition problem but I'm not too sure. I also thought perhaps I mixed up the lead wire from the coils but even when I reverse them it runs the same. How do I know which is the right way to have the leads hooked up? Someone told me to check for equal resistance across the coils but they appear to be the same. Both plugs have a spark but I couldn't really tell if it was equal.The motor stalls when I reduce the throttle to an idle but starts easily. So far I've only run the motor in a bucket of water and as far as getting it out on the lake, well that requires a bit of planning. Also the fuel is new so that is not an issue.
