9.8 merc half power under load
amplex
i have a 9.8 mercury thunderbolt s/n 7084063, not sure what year it is but would like to know if possible.<br /><br />The problem is it works fine in the test tank but when i put it on the boat and go for a ride, i can't get full throttle out of it.<br /><br />It idles fine but when i twist the throttle it will run at low rpm and only low rpm even with the throttle fully twisted.
JB
Re: 9.8 merc half power under load
Howdy, Amplex.<br /><br />Go to the Engines and Motors Forum and read through some of the dozens of questions just like yours. Follow the advice there.<br /><br />Let us know how you do. . . on the Engines and Motors Forum.<br /><br />Good luck :)
amplex
jb, i did a search on 9.8 mercs and found 20 questions but none with my problem
blifsey
I think part of what JB was suggesting was to this thread to the Motors board since it really relates to the motor itself.<br /><br />BL...
marvler
amplex, just wondering if you ever found out what your problem was, sounds like the problem Iam having with my motor.
amplex
marvler: Yes i did find the problem, as it turned out it was one faulty spark plug wire. I replaced it and the motor runs great again
