I have searched the site for answers and only find what I have already tried. My 1978 110 mercury 9.8 hp will not keep peeing. I replaced the impeller, and it is set well in the housing with the key pin in place. It is not slipping. With the lower unit off, I flushed all lines, cleanning out lines from water source to the pump and water tube to the taletail. With a water hose, I can run water from the lower water tube easily through engine and out the pee hole. In other words it appears nothing is clogged. The water pump housing appears to seal up easily and well. The gasket (if that is what you call it) in the housing that connects the water tube to the housing appears to be in good shape. Impeller spins as it should while hand spinning the shaft after the housing is back together. Once I put the lower unit on and run the motor in a bucket, it will pee at low speeds, but once the rpms go up, it stops and only air and steam comes out. When rpms are lowered back down, it still won't pee. If I kill the engine and restart, it will pee again. Im stumped. I do admit to not being familure with this motor and know im missing something. Im sure you fine folks can put me on the right track.
Thanks Kent.
Thanks Kent.
