fortunate2001
- Jul 1, 2009
- 36
Taking a slow dingy ride yesterday, and the motor starts bursting thrust for a split second, then gone, then again, then gone, no one touching the throttle. I think maybe one cylinder is firing, then not firing. I take off the motor cover, and find a small fountain of raw sea water shooting up from the engine. Closer look, there is a tiny hole on the top (see picture). Salt water has been spraying around in there for who knows how long (maybe a day or a week). I shut it down, poured a couple bottles of fresh water on it (just because that is what I had), and let it dry in the sun for a couple hours. Then I plugged the hole with some marine-tex, and gave it a few more hours to set. End of the day, tried the engine again, but still running poorly and stalling at lowest RPMs.
Tomorrow I will start to troubleshoot. I can see the metal on the outside of the plugs is already corroded, so probably more trouble to be found in the wiring. What should I inspect? Test? Should I try to do a better cleaning out than just the fresh water rinse?
TY.
TY.
