these motors are notorious for having an exhaust leak from a poorly designed seal. The seal is a pain in the arse to get to because I believe you have to pull the block?!?! someone correct me if im wrong, but thats what happens, exhause fumes choke out the engine with the cowling on and they are easily done away with when the cowing is off.
that is almost always the case with a the 9.5 motors.
thanks guys. i will order an empeller and seal.
