I have a 9.5 Evinrude that is around a 1970 model. It has a bad miss at idle. I have tried about everything I can think of. (Cleaned the carb, checked the valves, cleaned the crankcase breather valve, set the points......) Most people say to adjust the idle mixture, but that doesn't seem to get rid of it either. Could it be a coil, condenser, head gasket problem. It also seems to smooth out a little at idle if you hold the choke closed. Any help is greatly appreciated.<br /><br />Thanks.
