hi there i just bought what is theoretically a mid 90's 8hp johnson seahorse 2stroke, took it out on the lake today for a test run. and had trouble getting it to idle, or run at low speed, fresh gas, got it warmed up enough eventually to take a run, and it ran quite well at speed, but as soon as i brought it back down to try and troll it would run for maybe 30 seconds and stall, and would then be tricky to start up again, had to have throttle partially on to get it to turn over. modle # is cj8rcob also as i side note i cant make sense of the last two digits in the mo# as they would make it a 45 or 54? wich it most deffinately is not
