89 Yamaha 225 - Bogs Down
harrellusa
I just purchased a 89 Yamaha 225 to replace a 200 Mercury for my boat. The engine was installed and rigged by authorized dealer. When I open throttle to full, the engine revs up to WOT, but after only a couple of seconds, it starts bogging down to about 3500 - 4000 rpm. Dealer has checked fuel lines, pumps, plugs and thinks it might be the computer. Anyone else had any experience like this?
MIKENVAHBEACH
Re: 89 Yamaha 225 - Bogs Down
I have the same motor and the same problem, let me know whats up? would ya?
tgodiver
I had the same problem turn out to be the bad CDI unit, but it was a 98 Yamaha 225hp. I don't think CDI were put on 89 year models.
Capt Ken
You've got a bad fuel pump. The Yamaha V6's have dual pumps and if one goes bad, its does just what you describe. The second pump won't carry enough fuel to run the engine past 3000 rpms. If you slow down, the single pump will refill the carbs and you can run normally until the carbs run low again. Buy two kits and rebuild both.
FlyBoyMark
Ensign
Make sure you have the proper size fuel line for your outboard, you might have one too small...too long or clogged. Are you running a water seperator....could be plugged up too.
harrellusa
Anybody have any idea how much it should cost to have the carbs rebuilt?
blazed4x4
Ive seen a few problems on the 150- 200 yamis around that year with the same type of problem. Rebuilt the carbs two even three times. No good. Wound up replacing carb bowls cuz there was blockage under the seat(fuel inlet). Motors ran beautifully! p.s. seats are not removeable
