All right...
I've got a sweet tohatsu 15 that's having problems running in the mid speed range. it starts very easily and idles well. at top speed it really pushes my 14' skiff hard. the issue is the high idle to mid speed range. I was given this motor a number of years ago. I have used it and loved it but the mid range issue has gotten worse each year. It's so bad now that I don't want to run the motor anymore without hunting this problem down and repairing it. Being experienced with many kinds of engines on land and sea, I have taken precautions to be sure that it's not being starved of lubrication.
Here is what i've done so far (with no effect on the problem):
thorough carb cleaning (3 different seasons)
carb rebuild
new ignition coil
new spark plugs (every year)
replaced: cd ignition unit
replaced: upper crankshaft seal
checked: reeds (immaculate)
The upper cylinder is the one having the problem. I know this because the exhaust port for the lower one is immaculate with small portions of carbon the way a normal port should be. the port for the upper cylinder is gross with large amounts of unburned oil residue/fuel (looks like creosote from a chimney).
I will do another round of compression testing (readings were 115 and 125 last time).
Edit- I just did a compression test and my previous statement was wrong.
top cylinder got 125 psi
bottom cylinder got 124 psi both were dry. using oil did not increase these numbers.
Any opinions and suggestions are appreciated.
Thanks
Tator
carb rebuild
new ignition coil
Thanks
Tator
