'89 Mercury 70HP won't start
This is an intermittent problem. Ran fine last year, and it ran perfectly for an hour and a half this weekend. Then, I shut it down and wanted to restart it five minutes later. It cranked, but did not fire. I am not seeing a spark when I take a plug out and ground it to the block while cranking. It started one time when I switched the "dead man" switch from "off" to "run" while cranking. That made me think it is a short or loose connection in the Quicksilver remote, but I don't see anything. Anyone have any problems with the "dead man" switch? Ignition switch? Switchbox was replaced last year by the dealer. Any ideas?
Trent
Re: '89 Mercury 70HP won't start
You can buypass the remote by removing the wire from the powerpac and see if that cures your problem. ALso a defective mercury switch on the engine will keep it from starting. You can disconnect it also. (they dont go bad much)
