toneybrown
- Jul 1, 2013
- 104
Ok, this new boat is getting very aggravating. After address multiple issues in another post, I finally got the boat out on the water today to see if my fixes worked. Everything thing seemed fine, temp was a little over 145 at first. After leaving the dock and cruising about 15mph the temp seemed to stay steady, just over the 145 mark. I throttled down to idle in neutral and notice the temp gauge starting to creep up. It got to the mark between 145 and 220 F. Not sure exactly what that temp is..... Worrying of overheating I started back to the dock and the temp drops back down to just over 145F.. I opened her up to about 30mph and the temp stayed just over 145F the entire time. Tie off at the dock after cruising in, temp climbs back to the notch between 145 and 220. Kill the engine, open up the cover and the engine doesn't seem hot, exhaust is warm to touch but not scorching.
After putting the trailer in the water and going back to the boat to drive it up. I start the engine and it is nowcloser to the 220F mark. This was after being turned off for several minutes, the temp was reading higher then when it was actually running.
So, It has a new impeller and new T-Stat. Had the manifold off and it wasn't very corroded at all, seemed pretty clean. Didn't check the exhaust elbow. I have pulled the hose going into the T-stat housing and it had lowish flow on muffs at idle, and decent flow at higher rpm (Not sure exactly as Tach not working...).
Does this sound like a blockage someplace? Maybe oil cooling canister thing? What is the process of back flushing this drive?
Thanks again for any help!
