I have a oil tank problem or a module problem. I have replaced the sensor and it did not stop the warning alarm to shut off. The only other suggestion i have found was to turn the tank up side down to test the float sensor in the tank. IS there a better test to check the tank? And how do you check the module for problems?<br /><br />I apppreciate any suggestion.
