tblentrprz
- Mar 11, 2003
- 14
Greetings,<br />Trim/Tilt does not hold motor up/out. Originally no external oil leaks apparent. Recently external leak showing on tilt rod seal and port trim rod seal. Tilt guide scraper rotted away. Tilt guide was stuck in cylinder housing. Tried WD40 and another penetrating spray to free up without success. It required minor heat and 2ft long leverage to rotate. Noticed minor corrosion in top 2 threads of cylinder housing. What do you recommend to break corroded aluminum parts? Rod/piston came out no problem. The inner cup(deepest item in exploded diagram above oring) is stuck in cylinder. I used an allen wrench in the hex opening in the center nipple of the inner cup to try and rotate the cup without success. I tried 100psi of compressed air blowing thru the nipple to blow the cup out, didn't move. Tried using a PVC pipe and gently tap the cup back in some, no luck. What's it going to take to get the cup out and finish resealing this tilt cylinder? At this time I have not been successful rotating the trim sylinder guide. I haven't yet tried some heat. Looking forward to your suggestion on dealing with corroded aluminum parts and get your input before I proceed. <br /><br />Looking forward to your reply.
