teglovinvtec
- Jul 20, 2011
- 8
1989 johnson 28hp spl longshaft in fresh water only so the other day on my way back from a day of fishing and catching nothing my motor was running great and we were heading in and then it just reved up and woulndnt go into gear until i slowed down to a 1/4 throttle or less. its doing the same thing in forward and reverse. so i pulled to lower unit off and looked at the fingers on the clutch dog everything looked great. there were no metal shavings on the magnet either. so then i inspected the shift rod and also where it connects nothing seems bent.
put it all back together and ran it in my test bucket everything worked. headed down to the lake and it was doing the same thing when it was under load.
i know i didnt hit anything and ive had the boat out about 20 times before this happend this year not sure what to do. but the clutch dog looked great as well as the forward,reverse, and gears on the shaft that goes from the powerhead to the lower unit.
ive tried ajust shift cable didnt seem to help. please help me out its been a couple days and i need to be back on my boat.
is it possible the shift rod connecter could be slightly bent since its only brass???
please give me any info you have.
