mikesdad
- Sep 19, 2010
- 27
My Seloc ( I know, I should have bought a Clymer) book says that static timing should be set at 34' BTDC. (It specifically says 'Static Timing'.)
So, after I repaired the broken trigger arm, me and the boy ( so he could turn the key) went out and I set the timing---- and this is how I did it considering the Seloc book is so VAGUE.
Looking at the flywheel with the plugs out and grounded, and the flywheel spinning, I adjusted the trigger arm until the THIRD mark ( of three grouped together ) that are located to the left of the single mark that indicates TDC, was in line with the mark on the timing bracket.
From what I read here, that would actually be 32' BTDC.
Correct?
Ok then.
Didn't run the starter that long, maybe like 30 seconds at a time but when I put the plugs back in and tried to start it, it turned over like it had like high compression pistons in it.
Like it would hardly turn over.
This has been somewhat of an on going issue.
Since the trigger arm was broken before now, I thought maybe the starter was turning over slowly because the trigger had always been in a full advance, full throttle position.
So now I believe I have starter issues.
Agree?
Read this thread just now and that's what I'm probably gonna work on next.
forums.iboats.com/showthread.php?t=431379
Quite the winter project with this Force motor.
Correct?
Ok then.
Agree?
