89 force 50 not firing
Cham2012
I have an 89 force 50 thats been sitting awhile an both coils are not firing anyone have a wiring diagram or test procedures i can run???????????? Please Help
catfishcarl99
Re: 89 force 50 not firing
possibly the cd box???troubleshooting guides
http://cdielectronics.com/AppGuide.aspx
click link. then force motor. then check the HP box and click on 50. then click search, it will bring up stator and cdi and ect troubleshooting guides for prestolite ignitions systems.
cd http://cdielectronics.com/InstallSheet/IS-116-8301.pdf
stator http://cdielectronics.com/InstallSheet/IS-176-3095.pdf
rectifier http://cdielectronics.com/InstallSheet/IS-152-9209.pdf
trigger and coils there too.
jerryjerry05
Model#, serial#
Profile,location?
Does the boat have a kill switch installed?
Check all grounds and connections for being loose.
The connections on the pack,stator,trigger.
They can be bad under the shrink tube covering the connection.
I routinely replace them as I check the motor.
Then do as carl suggests.
