I purchased an 89 bayliner capri with the original force 50 engine. The motor idles rough sometimes and great others, it uses an incredible amount of fuel some of which is flowing back out of the carb into the engine case. I can not get the engine to rev above 4000 rpm. The motor seems to miss at all rpms.
I have cleaned the carburetor, replaced the reed valves, checked the ignition timing, ensured the appropriate prop is installed, rebuilt the fuel pump, installed a new fuel bulb. The compress test was 135 on both cylinders. I have also checked the ohms on the stator. There are two sets of winding for ignition with blue and yellow leads. The third set having green wires is the ac side. The ac windings are good. One of the two ignition windings is bad; having no continuity. The fine fellows at CDI told me that the engine only needs one winding to operate as this stator was used for three cylinder engines as well. The second winding is fine. The ohms are around 750. I checked the ohms on the trigger and they were 50 as per spec. It appears to have a strong clean spark on both cylinders. I replaced the plugs this morning and after two hours of run time they are black and gummy.
WHAT HAVE I MISSED???!!!!!!!!!!!
