I have a 89 Bayliner Capri with a Force 125 ob motor that is having intermittent starting issues. Before I brought it out on the lake this season it turned over just fine and started right up with the water ears on it at home. I came back out later that day and there was no power to the entire boat, nothing up front and nothing clicking at the motor and I have a 100% charged new battery. I tested for power at all the circuit breakers in the motor compartment and they all had power on both sides of the studs but the entire boat including dash lights, fuel gauge and ignition were not getting juice or the starter. I checked one side of the solenoid and it also had power so I decided to quickly jump the solenoid to see if it would turn over and it did. I then went back to the key and the entire boat up front had power and acted normally and the motor started just fine. I then decided it must be a loose/corroded connection somewhere so I loosened and tightened all the connections I could find in the motor compartment so this would not happen again so I did that and it continued to start as normal.
I decided to take it out on the lake this past weekend and as soon as I got there it did the same thing except jumping the solenoid did not work this time, in fact I am not sure what I did to it but it magically started again and I had a day on the lake starting it several times throughout the day with no problems.
Today I went to start it with the water ears again at home and the same thing happened, I can jump the solenoid and it turns over very fast, the circuit breakers all have power but now the entire boat is dead once again up front and I cannot get it to turn over at all, no more magical starting. I am not sure if it is not getting juice somewhere in the wiring in the motor compartment or if it is an issue up front or wiring in between or some kind of switch? Basically I am lost at this point.
Any suggestions would be greatly appreciated.
