bassndog80
- Aug 1, 2012
- 8
I have an 89 Evinrude XP 150 that will not turn over. The motor worked fine the last time I had it on the water. I have had the battery load tested and it checked out good. I have replaced the ignition switch and the starter solenoid with no change. I have checked the wiring on the boat side and it checks good for continuity and voltage. I have good voltage from the battery to the starter solenoid. I feel that the problem is on the engine side, I did check the one fuse that I found and it is good. The other problem that started at the same time is the power tilt and trip will not work. I replaced the relays and it still does not work. I'm not sure if the two problems are related or not.
