buzzman 9403
- Jul 20, 2003
- 51
over heat alarm came on 2 times put new water pump in. the old one was still good,took out thermostat for now til get new solved overheat i think ,but wont idle very well.130 compression ea. cylinder ,plugs are wet,sprayed stater fluid on outside motor to check for leaks no high idle from that, could it be electrical,lower unit grease clean no metal or burnt,took carbs off check floats and needle clean there too
