89 Evinrude 25HP Water Flow Issues
Viking59
Hi Folks,
I have an 89 Evinrude long shaft 25HP outboard that struggles to push water. The impeller was replaced recently. The symptoms are a little funny so I'm looking for suggestions before I spend a bunch of $$....
When you first fire up the motor it pushes water just fine. In gear it seems to also push a good amount of water with enough RPM. When the motor is warmed up, the problems start to occur...
In gear, at idle speed, no water out the tell tail. Pick up the speed and the water starts to come out here and there. Put the motor in neutral and the water comes out for a bit but then starts to spit periodically.
Recently we were out on the ocean and the water stopped coming out at high speed. Exhaust would be coming out of the tell tail but no water. Bringing the motor back down to idle did nothing to get the water flowing again. We used the kicker to get home.
When we got home and flushed the salt water out of the motor, there is a perfect stream of water again!
A little bit of background... This motor has been used a lot in salt water. I have had the leg apart and and the water tube is all clear. The impeller was installed by a professional marine mechanic. The original nipple that the tell tail tube attaches to at the top of the exhaust housing was made out of plastic. Upon removal a small piece of the plastic did break off and fall back into the manifold. This fitting has been replaced with a metal one.
I don't know much about thermostats on Evinrude engines. It is evident that the thermostat housing on this motor has been opened up and something in there has been removed or replaced.
I am tempted to buy a whole new water pump kit, thermostat + gasket and exhaust manifold gasket. I would replace the thermostat, replace the entire water pump and open up the exhaust cover to remove that little piece of plastic.
Any other thoughts or advise?
Thanks very much!!
jasper60103
Re: 89 Evinrude 25HP Water Flow Issues
Not much advice, but on my motors I replace the entire water pump just to eliminate other possibilities.
And be sure to use a trash can full of water. Muffs is not a good test for the water pump.
Also, while you have the gear case off, you may want to do the water pump test. Hope this helps. Good luck.
Daviet
jasper60103 is correct about running on a hose to check out a water pump, the water pressure will bypass the impeller and make it look like the water pump is working correctly. To test it you need to run it in a trash can with the water level well above the water pump.
If you are not sure of the condition of the thermostat it might be a good idea to change it, as well as the water pump.
