89 Evinrude 15 hp - impeller + water jetison question...
G8ER H8ER
Well, I posted another topic asking where the water is suppose to exit this motor put I used the word "pee" in the topic and it got erased - I guess the moderator thought it was foul language???<br /><br />But, I would be much appreciated if anyone can tell me how easy it is to check the impeller on this engine, and where is the water supposed to exit? <br /><br />The only place I can see it come out is a small hole directly in the center and about 2 inches below the cover (back side of motor). But it isn't a steady stream - it just blows out in spurts (in unison with throttle response). Is this normal water jetison for an older motor?<br /><br />Any and all advice welcome...
JB
Re: 89 Evinrude 15 hp - impeller + water jetison question...
Howdy H8er. Go back and read you other post. Nothing was erased. Also read the responses.<br /><br />Your impeller is failing or the hose is plugged up. Replace the impeller. Buy a manual.<br /><br />Good luck, <br /><br />Red sky at night. . .<br />JB :)
clanton
Look for a plastic nipple right side toward the<br />rear of lower engine cover. When you find it , start engine in water, give the nipple a blast of air.
petryshyn
Is it possible that this is an older engine with no telltail? I have an old johnson in which the water is spewed out of the exhaust relief port.(no tell tail other than that...) :confused:
clanton
That why he should post the model number, and I will look at parts book.
clanton
1980 has water indicater.
G8ER H8ER
Thanks for the advice. I think I will buy a manual and see how difficult replacing the impeller would be.<br /><br />I will also get the model ID # so I can figure out what year this motor really is.<br /><br />It definitely does not have a telltale - there is no nipple, and no water hoses inside the engine cover - just fuel lines.
petryshyn
she must be an older than she looks!!
G8ER H8ER
That she must! The boat was an 89 that I got with the motor and the motor has an 89 at the end of the id #, so I just assumed...<br /><br />If it were an 89, I have been told it should indeed have a tell-tale (which is not the case). I'm startin to think early eighties now. <br /><br />When I get home tonight I'll post the numbers to see if the forum's collective wisdom can shed some light on it for me.
