dabombman4u20062
- Jun 17, 2011
- 9
I just purchased this boat 2 days ago. well basically STOLE it paid $900. 4.3 OMC runs very strong and tops out at bout 40-45MPH. took it out for first time yesterday, and was taking on a bit of water. The seller did tell me about this and said his mechanic said it was prob from the O-ring in the exhaust.....it takes on to much water to be this i believe, not to mention the exhaust comes out of the prop thus would need lot of pressure to force water up into engine bay and leak as quick as it is. The bilge keeps up just fine however would rather not take on water. does anyone have any idea what could be? im going to caulk around the outdrive to see if that helps but i dont see any holes or major gaps around it. any input would help! also have to manually bump the shift linkage to get Reverse to engage.....lower shift cable? or does linkage just need adjusted? any input would help!
JErod
JErod
