Hi, I have the infamous L-Drive. Spent some time tuning carbs etc and have it running pretty nice. Installed impeller, a tell-tale and water flow is weird. When cold, I get fairly normal peeing. After a while at WOT, tell-tale just drips with some steam. Engine is cool to the touch - no alarms. Won't idle [warm] but with a touch of throttle it runs fine. Mechanic said any water from the tell tale means it's ok.
So here's the question. I want to put a temp gauge and/or water pressure gauge. Where can I buy and how to install? Tired of being paranoid. Also, why change in idle after running WOT?
