Impeller is good , All gromets and tubes sealed well. exhaust side cover and Cylender head cooling cover still running hot to to the touch, pumps a strong stream when thermostat opens but spits a little steam at shutting down. . the exhaust cover screws were dripping to the outside of the cover I made an attempt to reseal the screws and the tattle tale stream improved. is there a way to be more sure of the problem before I take off the exhaust cover and plate to examine the condition of the seal on the mating surfaces? Also . Can gasses transfer to the cooling system by way of the powerhead base gasket breach?
Thanks
Thanks
