Eddie Rivera
Thread starter- Joined
- Feb 19, 2013
- 183
Re: 89-50HP Carb doesn't fit on 91-50HP
Absolutely Jiggz, thanks for responding.
Guys, I have now received my carbie for my 91 replacement power head and I'm glad I won't need the solenoid primer cuz it's set up for the original mechanical choke - it's dirty and I know I can use the same bowl gasket but the part number for the two screw gaskets is different, I will make my own gasket and take pictures of the whole thing and be careful to only change what I can use and clean carefully as to not mess anything up nor deal with the float if it's not craked or damaged.
This carbie has two adjusting screws, not sure in that but please advice, also could you guys please let me know if I should use Loctite on the bolts holding the exhaust plate or what I did last time which is to use too much anti seize cream? I loosened it up real easy this time around which scared me and worries me about coming loose with vibration.
Please let me know on that too as I am about to get started now..... Good luck to me!!
