Greetings to the Board,<br /><br />When I removed my exhaust bellows, I found two exhaust seals that apparently had broken off and dropped into the pipe. I have yet to disconnect the pipe to remove them and am mostly wondering if this is a common problem and what purpose do they serve when in the proper place? During the last two seasons when running at WOT, the engine temp would soar and then bang and then stall. Now having found these two flappers, I'm wondering is it possible that they could have blocked the exhaust -- a la the old potato on the tailpipe trick -- and caused the overheating/banging/stalling?<br /><br />Regards,<br /><br /> --rml
