89 4.3 merc no spark
Cdclos1
Need a little help. Did a tune up on my boat and now it won't run. Cap, rotor, plugs and wires. Have no spark coming out of the coil. Checked for 12 volts at positive side of coil good. While cranking with a test light on negative side it stays lit just goes a little dim. Is this a sign of a bad pick up in distributer? If I ground the green and white wire with my test light I can get coil to spark.
alldodge
Howdy
I would first think to double check the rotor
