89 4.3 alpha 1 stalls when put in reverse
Deadeye1967
Title say it all I have a 89 Glastron Sierra 195 with a 4.3 alpha 1, shifts into forward fine 99 percent of the time but 100 percent of the time when attempting to shift into reverse the engine cuts out. It looks like there is a roller micro switch on the shifter asm on top. I'm a wrench so of course I had to push the switch when in neutral and yeppers, she cut out. Thing is, i cant see how the heck that switch would ever roll into the valley of the bracket to open the switch and thus allow the engine to run? Any Ideas whats going on here would be greatly apprieciated.
Thanks Deadeye :D
cr2k
Re: 89 4.3 alpha 1 stalls when put in reverse
Your lower shift cable is bad. At least that is what causes this problem most of the time.
Deadeye1967
I'm replacing the leaking bellows and gimble brg, guess I should get the cable and replace it while I'm in if the adjustment above doesn't help. Do the aftermarket cables work as well as the OEM ? Any aftermarket I should beware of?
Deadeye1967
Don S
Get the OEM cable. It's a MUCH better cable (teflon coated) than any of the aftermarket cables. And not much extra money for it either.
