This is a new topic from my previous topic which problems have now been corrected. Seems that there might be another issue needing attention. As a recap, originally the motor would stall out. Checked spark and noticed that I had no spark on #2 and weak spark on #3. Switch boxes were the culprit. Changed those out and good spark. Now, I get a stalling effect, that is only corrected by squeezing the bulb. The bulb is new(about a month old) and the fuel pump has been replaced. I have heard bits and peices about the bulbs and faulty check valves on non-oem bulbs(like mine). The problem of stalling is not consistent and rarely occurs on a full tank of gas so I assume it's the bulb. Can anyone confirm this? Any other ideas as to what can be causing this? Thanks for the help and previous responses on my other issues.
