89' 110 Evinrude
busterb
Hey all, back again. Just aquired a bass boat from my father in law. It is an 89' bass tracker fiberglass 18 footer with a 110 evinrude on the back. He bought it brand new, but the boat has been sitting for 7 or 8 years without being cranked. I'd say the whole rig has less than 100 hours on it. I'm going down to pick it up in a couple of weeks and would like to know from all the OMC V-4 crossflow freaks out there what to do before I try to fire it up. I know I need to immediately jettison the VRO and mix my gas, but should I just try and fire it up? Thanks.
keepiton2
Re: 89' 110 Evinrude
i just bought a 89 stratos with a 110 v4 on it . it sat 2 yrs.(they said) I ended up taking the tank out and cleaning it . I also changed every hose in between the tank and motor. I installed new fuel filter and water seperator. a new pickup tube was also in order. it took a little bit of time , but it runs great now . The thing was , I did it all in steps. I should have done it all right away and I would have been on the water sooner !! By the way , buy a manual !!!hope this works ! Skip
D
DJ
Guest
busterb,<br /><br />I like crossflows-true, but I'm not a freak.<br /><br />I would not disconnect the VRO-I like them.<br /><br />Here is what I would do.<br /><br />1. Replace the impeller.<br />2. Drain and refill lower unit-with new drain and fill plug seals.<br />3. Remove the oil tank and clean it out.<br />4. Replace the filter sock in the VRO tank.<br />5. Refill with oil and prime. Mark a line on the tank so that you can verify oil useage.<br />6. Check all VRO hoses for integrity.<br />7. Check all fuel lines under the hood and going to the tank.<br />8. Drain the tank and refill with fresh pre-mix-50:1, add a water seperator/filter assembly.<br />9. Ground the tan wire on each head to make sure the "hot" warning horn is working.<br />10. Verify you get a "beep" whenever you turn the key on.<br />11. Check all electrical connections under the cowl-especially the negative battery ground on the block. Take it off and clean it.<br /><br />Start it up and run it a while. Once you have a run it a while and it seems to be running good. Perform a decarb. procedure. Use the search feature on this board for instructions.<br /><br />Change the plugs after decarb.
Dhadley
It never hurts to clean the carbs and install quality kits.<br /><br />Good luck!
Dhadley
Oops! Forgot - I would pull the heads and change the 4 water deflectors and head gaskets.<br /><br />Sorry!
busterb
Thanks a million guys! I'm sure once I do that the motor will give me many years of good service.
busterb
Dhadley- what stainless prop and pitch do you recommend for this boat that will get me a good combination of holeshot and top end? Also, how much different is a 110 crossflow vs. a 120 looper in the power department realistically? I've read threads about a 110 crossflow making about 120 at the prop. Is this true? Thanks!
Dhadley
Although the crossflow is a great motor it will never make the torque of a looper. The 110 and 120 are totally different motors. <br /><br />I too have no problem with the oil pump. Keep water out of the tank and you'll be good to go. <br /><br />The best prop is one that allows 5800 RPM with an average load. If the boat has a jackplate I would definately lean toward a 4 blade. Get the motor up and running and we'll see where we're at with what you have. Then we can start changing things.<br /><br />Keep us informed and good luck!
busterb
Thanks a million Dhadley. I'm looking foward to playing with this thing and getting it set up. I still have to go pick it up down in South Georgia which will be an all day trip there and back. I can't wait!
