89 100hp merc 4cyl missing on one cyl.
Walli
put new plugs in, checked plug wires, chuggin real bad. pulled plugs, one out of four was as clean as it was when i put it in! Im handy with a wrench but Im stummped. Any solutions?
JB
Re: 89 100hp merc 4cyl missing on one cyl.
Hi, Walli.<br /><br />That usually means water in the cylinder. Do a compression test. You may have a blown head gasket. :)
Walli
Thanks JB, I've got a couple other opinions over the phone B4 I checked back here., one thinks coil cuz it's only one cyl., other thinks switch box. The later seems spendy but still cheaper than new motor. Either way a compression test still sounds like a good start, thanks again JB. <br />Walli
