I have a 1988 88Hp V4 with a sudden shifting problem. It shifted fine going into both forward and reverse at about 15 degrees either side of center and going into neutral with the shift straight up. All of a sudden it is shifting into reverse when pulling the shift back only slightly and does not go back into neutral until forward of center. I adjusted the shift cable and it worked better for a while, but is starting to do the same thing. The cable adjustment and cable jacket appear to be in good shape and secure, and the shift linkage appears to move smoothly with the shift control. I?m trying to figure out if there is a problem in the gear case. Thanks for your help.
