88 spl thermostat install. help needed.
boredindaboro
I ordered the thermostat kit for my 94 88 spl. There are no thermostats in the motor now. The kit has a bunch of gaskets and such and I do not know what order they all go in. Does anyone have an illustration or pics of what parts and what order these go in? Thank you in advance
boobie
Go to shop.evinrude.com, look up your motor and it will show you the parts break down.
boredindaboro
Thanks, but I need a better pic of what position and order all the gaskets and o rings go in
Bosunsmate
Its exactly like how the diagram shows.
The gaskets are obvious where they go
THe thermostats have the thinner bit poking backwards
the poppet valves have the bit which the spring goes on facing forward
you will need to post a picture if you want it clearer where everything goes
boobie
Did you go to shop.evinrude.com ?? If you did I can't tell you of any better diagrams!!
tblshur
boredindaboro, like boobie and bosunsmate said shopevinrude.com go to the midsection for your motor then use the + and - sign to enlarge the parts you need good luck:joyous:
