I have recently bought a 1987 Johnson 88 SPL. The compression and teltale are good, and it ran fine when it was attached to the seller's boat. Now that I have it mounted and installed on my boat, I had a little trouble getting it to idle right - seems a little high at ~1000 rpm at idle. I guess I probably need to do a link & sync.
But the main issue is now that the lower case is leaking gear case oil from around the prop. I am sure it was not doing this when it was on the seller's boat. Can a prop shaft seal fail suddenly like this? What might cause it? Should I replace all of the lower unit seals, or just the shaft seals? Any and all advice welcome. See leak pic attached.
Pete
Pete
