Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
does anyone have a schematic for the 88hp johnson with a vro tank. How reliable is the vro and There is no warning buzzer on my <br />boat for the vro, is it needed even if you put a little oil in your gas anyway. Sorry for allthe questions.
Some love the vro and some dont. I personally like to disconnect them and run 50:1 mix so their is no powerhead failure due to lack of oil. Are you shure you dont have the warning horn or is it just broken?? Its part of the VRO system.<br /><br />What kind of schematic do you want? One of the VRO system?
The horn is in one of two places..In the remote control (shifter) or under the dash in the accessory wiring. If you get a "beeping" horn you have a low oil condition (under 1/4 tank). If you get a continuous horn its an overheat condition.<br />You need to check to make sure the horn is working. Find the overheat sensors mounted in the block (should have two wires). Disconnect where its joined and turn the key on and ground the wire to the block..The horn should sound.
