88 Searay Sundancer 268 hinges etc
jdiddy127
Hey folks. I'm trying to track down some interior storage door hinges and the brackets that hold the legs to the bottom of the retractable rear deck bench seat. Anyone know of anyplace that sells that type of good stuff?
Jim
Sorrento 25
Re: 88 Searay Sundancer 268 hinges etc
Can you describe the parts better? I may have what you need. Or you can try Kendor Marine - www.greatlakesskipper.com They have an amazing amount of stuff. Everytime I go I find more goodies. :)
jdiddy127
The hinges are the same on each of the storage lockers in the cabin. They are small metal with adjuster screws.....sorry, don't have them with me so I'm going from memory.
The brackets for the rear bench seat are small and plastic. There are three of them mounted on the bottom side of the seat. The aluminum post style seat supports clip into the brackets and swing 45 degrees against the bottom of the seat where the bracket clips them into position so you can slide the seat away for storage.
B Williamson
I found some of the hinges at a cabinet shop in Richmond Va. I am still tring to locate the leg hinges for the back seat. I have a 1988 268 also.
