88 Omc 3.0L Power Pack question
Robreefer
Is there a way to test my Power pack? I see nothing in my service manual about testing it. I'm only getting spark on my 3 and 4 cylinders.
tashasdaddy
Re: 88 Omc 3.0L Power Pack question
are you counting you cylinders correctly?
tashasdaddy
are you counting your cylinders in correct sequence. some of those motors have a power pack for right and left cylinder banks. are you good cylinders on the same side?
Robreefer
Nope, the only two cylinders firing are the middle cylinders on opposing sides.
clanton
Do you have a peakreading meter?
clanton
If you are using a fluke meter, make sure it is not set on auto ranging.
If you are using DVA adapter, set 400 volts DC.
Fluke should check the ohms, I use fluke87.
Quick Start Timer is tricky to check.
