88' Mercury 90 2 stroke problems
anywhos
I recently bought a 88' tracker marine boat with a 90 hp oil injected 3 cylinder on it. I was told the motor was last run a year or so ago, and ran fine then! The motor will idle fine in neutral and in forward and reverse gears, but when throttled up the motor dies. New gas was put in, in line fuel filter was changed, drained the float bowls on the carbs and I put a new diaphragm kit in the fuel pump. Little to no improvement was noticed after these steps. Any suggestions? The boat was owned by people I know, it has low hours and is in immaculate condition.
Laddies
Banned
Re: 88' Mercury 90 2 stroke problems
sounds like the high speed jets are plugged
bfraser
88 90hp and mine runs great untill full throttle and it dies?? would that be the same type of fix??
