I have a 1988 100 HP Mercury outboard. I have replaced the rectifier, stator, trigger and switch box and I still cannot get a spark on any of the 4 cylinders. I plan on replacing the coils, but from what I hear it is not common to have all 4 coils go out at the same time. I have ran all the tests on the rectifier, stator, trigger and swichbox that CDI provided and they all are within range. I noticed in one of the tests provided by CDI it states that you should disconnect the yellow wires from the stator to the rectifier and try to fire the engine. I did this and I got it to fire, so I replaced the rectifier and I still have the same issue. The coils did test out of range, but is it possible for all of them to go out? Does anyone have an idea on where to go next or what to do?
