clint hawkins
- Jul 2, 2002
- 1
Initial problem: boat will turn over but not crank up. I first checked the kill switch and fuse. They were good. Next I pulled off the breather to see if I was getting fuel. Sprayed starter fluid and tried to crank again and it wouldn't. Next I checked the distributor cap and replaced it. That didn't work. Then wires, then spark plugs. No help. I then went to check to see if there was spark getting to the plugs. I took one plug out, grounded it to the engine, turned the key, and the engine ran. I shut it down,replaced the plug in the hole, and it wouldn't start. I took the spark plug back out and it cranked as soon as I turned the key, no problem. I then put the plug in, took the wire off the plug, and it wouldn't crank. I replaced the wire, took a spark plug out of the opposite side, and it fired right up. I removed the valve covers to ensure that all my valves were properly seated and functioning, everything looked great. Best I can figure, I have a compression problem with the exhaust, but I don't know enough about it to say for sure. The compression on each of the spark plugs is good. but the engine will not run unless I have one spark plug out of the hole. Did the 88 model come with gremlins? Appreciate any feedback. Thanks a lot. Clint
