First time posting, so I apologize if this has been covered in a previous post.
I have an 88 Mercruiser 5.7L Alpha One I/O that is not shifting correctly. It will shift into forward and reverse from the neutral position, but will not return to neutral with the engine running.
I have realigned the shift cables to ensure that they are set to factory specs and checked for excessive 'play' in both cables. Both cables appear to be well within factory specs for play/stretch.
I am wondering if my shift interrupter switch may be going bad, but I can push to button in and it does kill the engine.
NOTE: I did have the lower unit off over the winter when I replaced the bellows. I did not replace the shift cable at the time, which was a mistake in hindsight.
Any help would be greatly appreciated.
