The Teleflex temp gauge will go to 0 when the ignition is turned on, which I take to mean the sender is properly grounded, but the gauge never registers above 0, even after running WOT for a few minutes. Motor still runs and starts just fine. Do I have just a sender problem, or could it involve something else as well (thermostat). Would I be correct in saying that if the temp never rose at all, the engine would have problems? I understand that if the sender is not grounded to the block, it would not do anything at all.<br /><br />Thanks
