88 MARINER 25HP 2 stroke won't start
Story84
I have an 88 2 stroke outboard Mariner that wont start I changed the CDI and it started fine push the throttle and now it won't do nothing change the fuel pump diaphragm And still nothing I have spark but plug s have fuel on them .first boat I know nothing. ..
Story84
Spark seems a little weak Serial numbers 0c117449
There s another # 54935.
I disconnected the kill switches from the cdi and same when it was running we pulled one plug wire at a time and it stayed on but when we gave it throttle it kinda backfired and now I can't get it going again
flyingscott
Check the flywheel key could be sheared. Do you have the plug or coil wires on backwards.
Story84
What do you mean by backwards on coils I only connected the one's from the cdi does it matter which one fire's first or something ? I'll check out the flywheel key
flyingscott
Yes it matters how you hooked up the coils each cylinder needs to fire at a certain time.
Story84
Runs like a champ .but want to make sure I have the right torque on the fly wheel does 110-125 lb sound right I read that some where
