25whaler
- Nov 24, 2003
- 33
I am still getting alot of excessive smoke at startup. Have changed to champion plugs and ram oil in hopes this would help. I also have replaced with two rebuilt vro from dti. I was running 50:1 premix a year ago with the same amount of smoke. Any suggestions, I am going to rebuild the carbs as this is coming up on the time to do so?? I am ok with alittle smoke but I am having alot at startup and also at idle even after a long run. Is there air leaking into the fuel before the carb??? Also When I started them today at idle i trimmed the motor up slightly and the idle increased. What does this mean. I will also decarb this spring to try to help. Compression is good and motors run very well at wot. Any help please would be greatly appreciated.
