88 GT200, I want to Run out of gas???
Livewire
Man, does this place have the information or what. I have been reading for days about everything. I have read on this site for days and days and the different stuff that could cause problems and how the repair and trouble shoot the engine. :D
I have made some moves with my motor that I would have paid to have done had I not heard about this site. More on who sent me later in the post, you won't beleive it...:confused:
I have disabled the VRO and premix the fuel.
With premix is it good for the engine to run it dry for storage? Longer than a two week time. I have read post that pointed the problems with doing it while the VRO is in place, don't remember seeing this question.
The same weekend (Friday evening) that I disabled the VRO, I de-carboned the engine, using the 3/4 gallon, 16 seaform, 3 oz of 2 stroke, run 15 mins and off 15 mins. Interesting results other than cleaning the engine, it only takes 30 mins in my engine to burn up that much fuel...
Then used another whole can of seafoam (I poured it into a spray bottle) pulled the plugs and used it up on the interior of the engine.
After watching the weight in at Paris Landing KY (Saturday) and see KVD win with 92lbs 5ozs.:cool: I waited an extra day before tossing the boat in the water to burn of the seafoam. By Sunday afternoon, looked like road tar dripping off the scag, shook the boat off in the water, got it runnung, smoked real good for about 3 mins. Runs great. Just won't idle after 5 to 8 mins in the water, so I have ordered the carb-kits and plan on cleaning the next weekend.
Thanks again for the great information and help that is provided here. I have read the tips for getting the questions answered here; and by the size of my post, I blew it. I am just so thankful for the time and attention that is shared here to help others and save money.
Now the the teaser on how I found this site... The Old Bait House Of Paducha Ky. The very place that sold me my boat on May 10 2010. That is right, the owner, Steve Ballard, is doing the same thing in person that all of you do here, help one another out. Its werd to get that kind of help from a boat service store.
Until next time:).
Jay
ondarvr
Re: 88 GT200, I want to Run out of gas???
While some people will run smaller single carb motors dry and think they've run it out of gas.....it only lowers the fuel level in the carb....the carb isn't empty. It has used up all the fuel and oil that was coating the other internal parts though....the ones you are trying to protect with extra oil when fogging for storage.
On multi carbed motors some carbs will run out fuel before others, but it will continue to run while dragging those dry cylinders along for the ride.
After saying that....people do it both ways and report few problems either way.
If you don't want gas in the carbs during storage then drain the carbs manually, there's a drain plug on the float bowl designed for this purpose. Running it until it quits does not drain the carb.
kenmyfam
As said above. People do both methods. If you do not drain it then make certain the fuel is treated with stabilizer and run through the entire fuel system. (That is my "preferred" method) before storage.
