88 Force 85 Fuel Pump question
further
Anyone know the best place to pick up a fuel pump diaphram online? Is this a necessary component to replace in the process of tuning up? And is there anything else with the fuel pump that should be replaced. I just bought the boat and don't know how long its been sitting (at lease since last summer).
Thanks in advance.
chitownborn
Re: 88 Force 85 Fuel Pump question
you can order them right here on iboats, one thing to check for while you have the pump off is the check valves, theres three of them but youll only be able to check two of them[ one is pointing the opposite way] just take a pencil with an eraser, take the eraser part and push lightly on the check valve buttons[ in the center] after pushing they should release, if not there gonna need to be changed, i do my diaphrams at the start of the season, for under twenty bucks and easy to do its worth the peace of mind good luck don
