My trim and tilt started to not work correctly the last few times out. It works fine going down. It will move up(expecially trim) but much much slower then normal. When it gets to tilt it will move slightly then you will hear what sounds like the motor giving up. It seems like it does not have enought power to lift the motor. So I have had to help it up while someone is holding the switch to load it into the trailer. It will still hold it's position relatively good. <br /><br />This problem first started after I replaced an ignition switch. I had removed all the wires from the battery when I changed the switch so my first thought was that it was not getting a good connection after I reattached everything. So I brushed all the connectors and reattached the wires and the trim/tilt seemed to work fine. By the time we were at the lake it was back to it's low power problem.<br /><br />My first thought is that it is a poor connection to the battery. But is that possible that it can draw electricity but not enough for proper operation from a bad connection? Or is it a all or nothing type thing? If the pump in the TNT is going, do they lose power first or just stop completely? It hasn't stopped yet, it always tries to operate.<br /><br />Any suggestions?
