i recently did a carb rebuild, and cleaned the interior of the cover, and below the engine. i took it out for a test run and everything ran great. when i got back to inspect, i noticed some oily under the control cables, and the bottom of the exhaust cover. im trying to get all the leakys fixed. i cant locate where the oil came from under the control cables, as the only place wet is at the bottom of the exhaust cover in the rear. is it difficult to change the exhaust gasket, and does it hurt to run it until i have time to fix this?
had it tuned last fall, and compression was good. I dont think the head gaskets are leaking.
