Re: 88 25 hp merc
Hi Murray<br />Some times when cylenders over heat the rings just become stuck in the ring groves.<br /> I would try soaking that hole with a decarb product. Soak it, turn it over, soak it some more. Play with it a couple of days. Retest compression. I still bad remove the exhaust cover on the port side. This should give you a look at the rings and cylender walls. Push on the rings with an awl to see if they are springy. Remember this is kind of a long shot. If I had your motor, and the decarb didn't work. I would probably go for over hauling it myself.
